I want to install a switch to rear 12V plug | Ford Explorer Forums - Serious Explorations
360
Sarasota FL
2015 Explorer XLT
I wish to be able to control the power to the 12V plug in the rear cargo area via a switch in the drivers seat area. Does anyone know where I can tap into it and install the switch?
I believe it has its own fuse but you would likely need a wiring schematic to know which wire goes to it. Perhaps this is something that either jmr061 or sheltonfilms would have.
ever figure this out?
I'll look at my wiring diagram later on I do believe it is the brown with red stripe on the master harness under the dash of the c212 I'll look later and get you the exact pin number on the connector
