natenkiki2004
Blue Bomb!
- November 3, 2013
- Location
- North Idaho
- 1991 & 1994 Explorers
I have a 1991 v6 Ex with 230k miles on it and when I got it, it had severe starting issues. It would never start the first time you cranked it. It would start the second time but even that was a little shaky. After some troubleshooting and tuneups, I found that the Intake Air Temp sensor was extremely faulty and replacing it made the Ex start right up.
Right after that though, I developed another issue. When cold, the idle would hunt around a little bit, surging up past 1K RPM and then heading back down to 800 RPM or so. It would do this until warmed up. I cleaned the IAC before replacing the IAT sensor (I found that thread with pictures) but didn't use a new gasket when installing. I also used carb cleaner NOT electrical contact cleaner (oops...).
Fast forward to today, the last couple of times I start the Ex, it really stumbles and has very low RPM for a few seconds, to the point of sounding like it's going to die. Running some errands today, I restarted the Ex when warm and it seemed a bit shaky but not nearly as bad when cold. I got home and pulled the IAT and IAC. The IAT tests fine for now (I'll check more later) but I'm a bit confused on the IAC readings.
Looking at this thread:
http://www.explorerforum.com/forums/showthread.php?t=232262
I should have 2 different readings when probing the pins, depending on polarity? I get 9.7 ohm no matter which polarity I probe with. That's 9.7, not 9,700. As far as I can tell, this IAC is stock (the previous owner replaced a lot of parts with non-OEM aftermarket ones and this has the FORD logo).
Does my IAC seem fried? Perhaps I fried it with carb cleaner or maybe it just bit the dust after 230K miles?
Thanks.
Forgot to mention, my IAC looks like this:
http://i.fixya.net/fixya20/uploads/images/jturcotte_524.gif
Not the one shown in the cleaning thread:
http://www.explorerforum.com/photopost/data/503/3661iac_before_low_res.jpg
Thanks.
