Idenifying a 5r55s | Ford Explorer - Ford Ranger Forums - Serious Explorations
Idenifying a 5r55s
shawn022
Williamsburg VA
2003 Explorer XLT 2WD
How can you tell the difference from a 5r55s and a 5r55w? And 5r55e's have a dipstick,correct? I have a line on one that is out of the vehicle so I want to make sure it is the right one. Im needing a 5r55s 4.0 2wd. Thanks
Bobmbx
King George, VA
2016 Explorer Platinum
Idenifying a 5r55s
Look for an Explorer on the back of a flatbed tow truck. Thats how.
shawn022
Williamsburg VA
Haha. I always think timing chains when I see that.
Boonie2
South Florida
2003 Sport Trac XLT
Pretty sure that was a serious question
shawn022
Williamsburg VA
Yes, definitely a serious question. Anyone have an answer? I've read that it doesn't matter if it's a 5r55s or5r55w, they'll both work. But then again, you can't believe everything you read on the Internet.
JK080
Transmission Moderator
Staff member
Moderator
North Ga
05 F250 6.0
There is no way to identify the 5R55S from the 5R55W without taking it apart, the 5R55E looks different and has a dipstick.
The 5R55S and W can be swapped around, but I think the later models will set the check engine light for gear ratios errors. Somewhere around the 04 and later models, I am not positive on this but I did read it somewhere in a tech bulletin.
shawn022
Williamsburg VA
Thank you.
rwt101
pigeon forge tn
2005 Explorer
You should also be able to tell by the tag on the side of the trans if it is still on it.
Bob T
shawn022
Williamsburg VA
Bob T
Would the tag actually say 5r55s/w or would it be some type of code? Thanks
rwt101
pigeon forge tn
2005 Explorer
It would be a code. I am pretty sure I was able to do a search with the numbers and it told me what it was. Also if it is still with the car you can look at the plate on the drivers door under tr for trans and if it is a 5r55s there should be a "v" there.
Bob T
rwt101
pigeon forge tn
2005 Explorer
The top numbers on mine are 4L2P 7000 AB. Mine is a 5r55s with a code "v" on door tag under tr for trans.
Bob T
:usa:
shawn022
Williamsburg VA
Well, I'm still after a transmission since getting the run around from the seller. Usually its the buyer that backs out but not in this case.
