Idle Issues | Ford Explorer Forums - Serious Explorations
Idle Issues
olathe04si
Olathe, KS
1994 Ford Explorer EB
I've tried searching for my issue on the forums but have had no luck. I have a 1994 explorer Eddie Bauer with 180k. When my car warms up and I'm idling, something underneath the hood starts up and my rpms jump up about 500. Then after about 4 seconds it shuts off and idles normally. It does this about every 20 seconds when I'm idling. When this things turns on there is a slight squeek at first. I'm not throwing any CELs. Thanks in a advance.
I had that problem with my 97 and changed the throttle position sensor. presto!! problem fixed. hope this helps!!
Ill go pick one of those up tomorrow and give it a shot. Thanks
I let my car idle this morning while I checked underneath my hood and I realized that it was my AC condenser kicking on and off. I had the car in defrost and I forgot that defrost kicks on the condenser. Is it normal for it to kick on and off like that?
I heard my compressor kicking on/off the other day w/ the defrost on and I was under the hood.
