Rich A
- December 12, 2007
- build process
Thought I would post this to help others.
I have a 1997 5.0L. The Idler pulleys bearings were bad.
I took the bearings out of the pulleys.
Found one pulley bearing that read NTN 6203LU.
I.D. was 0.66 in. (17 mm), O.D. 1.57 in. (40 mm), width 0.47 in. (12 mm)
The other idler had the same size bearing.
I found a cross reference for this bearing (Not sure how accurate it is).
NTN 6203 LU
NSK 6203 DU
SKF 6203 RS
*** 203K P
MRC 203S Z
KML 6203 2RS
Motor City SL 203 FF
HTH
NTN 6203 LU
NSK 6203 DU
SKF 6203 RS
*** 203K P
MRC 203S Z
KML 6203 2RS
HTH
