Idling Rough
Punjab
Colorado
'94 Limited
This last week I started having rough idles after starting and once I stop at a red light. There is also some black crud collecting on the snow/ground near the tail pipe while it's running.
So since I'm due for an oil change I thought I'd Seafoam it and try to pull the codes. I popped the hood and started by removing the intake tube. When I pulled it off I turned it over and noticed some good sized cracks in the flexible sections on both ends. Is it possible that this could be my issue? I figured additional air entering the engine after the MAF can't possibly be a good thing.
Should I try making a shiny custom intake pipe or hit a junkyard for another plastic one?
Should I keep digging on the engine? I checked a couple spark plugs and they were dark but didn't look bad to me otherwise.
Join the Elite Explorers for $20 per year. Gets rid of the ads! New $5 per month option.
Wolfie_85
Iowa
1994 Ford Explorer XLT
Those intake tubes are plentiful and cheap at wrecking yards. I'd look there first. Some are in really good shape. I got one there.
Clean your MAF, try seafoaming it, and if your plugs are too new for you to want to replace, clean 'em up. See if it helps. Might wanna clean your throttle body, too. Not saying it would help the blackening snow, but it might help your idle. Notice it burning oil at all? You might just be running rich from all the unmetered air.
mekelly
Marietta, GA
The unmetered air could definitely cause idling problems. You'd be running lean though, not rich.
malohnes
SE Alaska
'91 xl m5 4x4
Definitely an issue here. There could be others, but this is a given and an easy repair.
Punjab
Colorado
'94 Limited
$20 for a salvage yard intake and it seems to be back in tip top! I drove around and didn't get a check engine and it was idling great again.
Thanks guys!
Rhett
Let Them Eat Cake
Cape Girardeau, MO
94 Sport 4x4
That's great! I was going to say...you can repair your old intake tube, using Permatex Black. Yours doesn't look too bad, I think the Permatex Black would set up well in those cracks.
BTW, I had a hole in my intake tube also...and it caused a lean condition / pinging. After I resealed / repaired the tube, all's well.
natenkiki2004
Blue Bomb!
Location
North Idaho
1991 & 1994 Explorers
As Rhett said, I'd keep the old one and goop it up for a spare. Pretty blatant problem and cheap fix too!
4 hey did some stuff to my truck, and now its idling rough Stock 1991 - 1994 Explorers 10
D Rough idling, vibration when accelerating in high gear Stock 1991 - 1994 Explorers 4
D Rough Idling / Stalling Problem Stock 1991 - 1994 Explorers 6
R 91 Navajo idling rough Stock 1991 - 1994 Explorers 2
S 1993 ford explorer xlt starting/idling problems Stock 1991 - 1994 Explorers 2
L Help shifting and idling problems Stock 1991 - 1994 Explorers 1
F loads up when idling Stock 1991 - 1994 Explorers 7
B Hesitation with an idling problem. Stock 1991 - 1994 Explorers 4
S Not idling. Stock 1991 - 1994 Explorers 1
J Strange Idling Problem Stock 1991 - 1994 Explorers 1
N high pitched whine coming from gas tank when idling Stock 1991 - 1994 Explorers 1
P 94 xlt chugging while idling!! Stock 1991 - 1994 Explorers 6
C Idling Problems Stock 1991 - 1994 Explorers 2
S from clean trany to idling problem Stock 1991 - 1994 Explorers 1
T replacement radiator now causing rough idle Stock 1991 - 1994 Explorers 4
B Runs rough or stalls when started warm, otherwise OK Stock 1991 - 1994 Explorers 7
S 1994 Sport rough idle Stock 1991 - 1994 Explorers 1
C 94 ranger rough/low idle Stock 1991 - 1994 Explorers 7
C First hesitation, rough idle, then no start... Stock 1991 - 1994 Explorers 4
M Rough Idle and Noise from Intake(?) Stock 1991 - 1994 Explorers 8
T Idles Rough, Lean codes Stock 1991 - 1994 Explorers 2
S Rough Idle when engine is hot HELP!!! 1993 explorer Stock 1991 - 1994 Explorers 10
B New to Forum, Rough running. Stock 1991 - 1994 Explorers 6
J Intermittent rough running, Code 214 Stock 1991 - 1994 Explorers 6
T Stump the chump, round two. Rough start... Stock 1991 - 1994 Explorers 14
O Rough engine idle and miss Stock 1991 - 1994 Explorers 7
K Rough idle on cold start Stock 1991 - 1994 Explorers 17
B Rough shifting after new cluthch and slave Stock 1991 - 1994 Explorers 10
M poor gas mileage/rough idle on start/lose power after warming up Stock 1991 - 1994 Explorers 21
9 Rough running/Sputtering Stock 1991 - 1994 Explorers 7
L Rough idle no power Stock 1991 - 1994 Explorers 5
timtimtimajim Rough idle on warm start Stock 1991 - 1994 Explorers 9
G rough idle code 41 Stock 1991 - 1994 Explorers 2
T Solved [FIXED] Running extremely rough/rich on cold starts (w/ video) Stock 1991 - 1994 Explorers 13
D Rough cruising idle, check engine light flicks on and off Stock 1991 - 1994 Explorers 0
W rough idle, wont start sometimes Stock 1991 - 1994 Explorers 5
T stalling and running rough after warning up.. Stock 1991 - 1994 Explorers 15
C Rough idle Stock 1991 - 1994 Explorers 4
M Oxygen sensor; replaced, now runs rough & "check engine" Stock 1991 - 1994 Explorers 1
R Intermittent rough idle on warm start.... Stock 1991 - 1994 Explorers 36
D codes for rough running stock 94 Stock 1991 - 1994 Explorers 3
1 '92 Explorer rough idle...only when defroster is on Stock 1991 - 1994 Explorers 1
D Changed spark plugs and now runnings really rough Stock 1991 - 1994 Explorers 18
R Rough Idle, Vibration in reverse gear and taking off. Help! Stock 1991 - 1994 Explorers 4
H Rough idle, spitting carbon...Please, I NEED YOUR HELP. Stock 1991 - 1994 Explorers 2
P Sputter, Stalling, Rough Idle, Dying when Hot Stock 1991 - 1994 Explorers 4
W Another Rough Idle Problem Stock 1991 - 1994 Explorers 5
B rough idle Stock 1991 - 1994 Explorers 2
H Rough Idle when warmed up Stock 1991 - 1994 Explorers 40
F Running rough all of a sudden! Stock 1991 - 1994 Explorers 1
Similar threads
