IDS programming
diveguy7
2016 Explorer PIU
So I have gone back and forth with my local dealer on correcting a few things on my 2016 PIU. Specifically enabling the autolock and installing one of Jason’s patches to enable the sun sensor for DRL. (Have tried Forscan, I done a TON of other things, but it won’t fix these)
They *will not* budge on installing any aftermarket software.
Does anyone in Central/East Florida know of a dealer that is open to this or have access to IDS software?
Thanks in advance for any help.
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
I believe all dealers have access to IDS. I'm not surprised that they won't do anything with aftermarket software. It could be a 'liability' issue. You are not the first one to be turned down.
diveguy7
2016 Explorer PIU
I figured, but I imagine someone has had better luck than me out there....hopefully someone in FL?
pdxgeek
16 PIU EB
16 Focus RS
You may be able to accomplish some of this with Forscan and a good bluetooth or wired OBDII connector like the OBDLink MX. I changed a myriad of things like unlocking rears/hatch with fob. I believe mine autolocks as well currently, so may be able to find that setting in Forscan.
diveguy7
2016 Explorer PIU
Have an OBD link and Forscan and have already done many tweaks to my PIU. I have tried to toggle the autolocks and proper DRL/sunsensor operation but no luck....
KayGee
Farmington, MI
'16 & '17 PIU
What do you mean when you say "correcting a few things on your PIU?"
Dealers and Ford (and their software/tools) aren't there to help you/us bypass their process and add features to a vehicle that wasn't ordered in a certain way (although they will typically help with some basic stuff like adding keyfobs for rke). I would venture that most won't help as it probably violates their terms of use for the software, not to mention the liability previously mentioned.
If you find a dealer that will do it, that's great. If you don't, you will have to do your best with forscan or make do without the feature.
diveguy7
2016 Explorer PIU
Poor choice of words - i am referring to a “grayed out” autolock menu item in the IPC that I simply wanted to enable.
edougawa
2013 Police SUV
Maybe you need to find a friend who can lend you a IDS.
I made the auto lock function selectable on the IPC (with ForScan) but still seems like it is not doing anything after being enabled. Maybe it is something more than just a setting (just like the aux switches setting).
By the way, I don't see the link between the sun sensor and the DRL (maybe you mean auto-lamp?). I got my auto-lamp switch and also DRL working (although I'm too lazy to add a sun sensor) with ForScan.
KayGee
Farmington, MI
'16 & '17 PIU
Some features require changes in more than one module.
