If I never change a balljoint again....
JuBean
Roxborough CO
2002 Sport Trac
I would be happy!
Do you guys have any tricks to getting the lower joint out without red neck engineering? The bushings on my upper control arms were shot so I decided to change all of the joints and while the upper is easy enough the sadistic engineers at Ford did not leave room for a receiving cup on the lower side of the arm hence the picture below. Is there a better tool for the next time I need to change these?
gmanpaint
It's Always Something!
Staff member
Moderator
MO MO
94 & 95 XLT's
The C-Clamp tool is only used to install the lowers in my shop.
To remove the BJ, heat the stud with a plumbers propane or Map torch for a minute or so, brace the LCA and hit the top of the BJ with a 3 or 5 lb maul hammer until it pops out. Just make sure to get the C-clip off before smacking it. LOL!
This is not REDNECK, this is the way to get er done. ;)
MidnightRebel07
Pittsburgh, Pa.
2003 Explorer Sport Trac
Can't tell but did you remove the snap ring that holds the balljoint on? Just asking. If you have a harbor freight near you go get their electric impact gun (Life Saving Tool), I've used this on tons of projects and saved my knuckles, patience, the neighborhood from hearing my yell and curse for hours, etc... LOL I used HF's balljoint tool kit and their electric impact gun, it was easy.
For the lower balljoint lube the hell out of it with PB Blaster or WD40 and than take a BFH to the top of it and it should pop right out. Place a block of wood under the lower control arm or a jack stand with a piece of wood so it stays still and doesn't rebound after the hit.
MidnightRebel07
Pittsburgh, Pa.
LOL, Gman beat me to it while I was typing and trying to contain my 3 year old from destroying the house.
JuBean
Roxborough CO
2002 Sport Trac
Lol I did use the BFH to beat on the press once it was loaded and that finally got them to move.
MidnightRebel07
Pittsburgh, Pa.
Cool, glad to hear you got them out.
T Never seen a rear main like this one before... 2001-2005 Explorer Sport Trac 6
O could never start it up (turn over engine) on a cold start 2001-2005 Explorer Sport Trac 4
B My back power sliding window goes down but never comes up. 2001-2005 Explorer Sport Trac 6
M Thermostat Change 2002 Sports Trac 2001-2005 Explorer Sport Trac 5
P Differentail oil/fluid change 2001-2005 Explorer Sport Trac 10
N Transmission fluid change 2001-2005 Explorer Sport Trac 2
N Oil change with different oil ok? 2001-2005 Explorer Sport Trac 5
P '02 Oil Filter Adapter o-ring change 2001-2005 Explorer Sport Trac 6
S Help Electrical Issues after coolant change 2001-2005 Explorer Sport Trac 2
B Wheel bearing change, Can I use 4x4 wheel hub on 2wd? 2001-2005 Explorer Sport Trac 3
T The four hour oil change 2001-2005 Explorer Sport Trac 27
C Transmission filter change now causing trouble. 2001-2005 Explorer Sport Trac 13
S New Plugs and wires, BIG CHANGE 2001-2005 Explorer Sport Trac 8
B blower motor change? 2001-2005 Explorer Sport Trac 9
E Steering wheel off center after PS rack and pump change? (Long) 2001-2005 Explorer Sport Trac 7
O oil change without washer 2001-2005 Explorer Sport Trac 5
B Wheel size change 2001-2005 Explorer Sport Trac 1
F 2003 Sport Trac 2wd with 98,000miles change transmission fluid or no? 2001-2005 Explorer Sport Trac 6
G filter change on tranny after 250000 2001-2005 Explorer Sport Trac 1
J Transmisson Fluid Flush/Change? 2001-2005 Explorer Sport Trac 10
O should i change out my water pump and thermostat? 2001-2005 Explorer Sport Trac 7
D 03 Sporttrac Auto Tranny Fliud Change Additive? 2001-2005 Explorer Sport Trac 3
LONO100 time to change brake pads - any recommendations? 2001-2005 Explorer Sport Trac 10
W 2001 Sport Trac lower Ball Joint change 2001-2005 Explorer Sport Trac 7
S Body Mount Bushing- Change 2001-2005 Explorer Sport Trac 7
Gse Brent Trans oil change 2001-2005 Explorer Sport Trac 27
M How do I change the fuel filter metal end? 2001-2005 Explorer Sport Trac 4
D Rear end oil change 2001-2005 Explorer Sport Trac 11
0 Center console change 2001-2005 Explorer Sport Trac 4
LONO100 im approaching 80k miles, should i change my tranny fluid!? 2001-2005 Explorer Sport Trac 7
T front differential seal change 2001-2005 Explorer Sport Trac 1
A Rear Diff Fluid Change 2001-2005 Explorer Sport Trac 7
8 change coolant 2001-2005 Explorer Sport Trac 0
F How do I change the rear brakes? 2001-2005 Explorer Sport Trac 10
T tranmission pan gasket change 2001-2005 Explorer Sport Trac 3
S Trac won't start after plug/wire change... 2001-2005 Explorer Sport Trac 3
J Can't get hub apart to change bearings on 02 2001-2005 Explorer Sport Trac 2
T Transmission Change Question 2001-2005 Explorer Sport Trac 3
04trac '04 battery and alt change. 2001-2005 Explorer Sport Trac 7
M Help...just screwed up 1 lower balljoint installing it? 2001-2005 Explorer Sport Trac 11
Similar threads
