Ignition cylinder replacement. | Ford Explorer - Ford Ranger Forums - Serious Explorations
bigblockford
cape breton
2000 5.0 ford explorer
anyone have any idea on how to get the ignition cylender out of a 92 explorer lost the keys so i decided to beat out the old one now i found another one with keys but im wondering on how it comes out.
bigblockford
cape breton
Push up on the lock cylinder retaining pin with a 1/8 in. (3mm) diameter wire pin or small punch. Pull the lock cylinder from the column housing
da2962
Norwalk, CT
2003 4.0 XLT
The key has to be turned to the on position to depress the retaining pin. Once its turned then the retainer should push in easily. It should be located about 3/4 of the way down on the housing on the bottom (you should see a small hole with the retainer)
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
