J_C
- July 30, 2009
- Florence, KY
- 1998 XLT 4WD 4.0L SOHC
Apparently the last time I'd parked my X I had just turned the steering wheel a little to the left (barely, more like only pressure that direction than turning much) and was still applying pressure to it when I turned the ignition off.
That resulted in resistance to the right which put the steering wheel and ignition lock in a bind. After 5 minutes trying to turn it using two different keys I figured I needed a new cylinder or something else in the column, but finally tugging the steering wheel back and forth while trying to turn the key freed the cylinder.
Has this happened to anyone else? It's never happened to me before though I'm not usually turning the wheel at all when the ignition is turned off.
Is it a sign that something needs lubed or is wearing out?
