Here is my dropped `92 4-door:
Front:
3"drop I-beams from Aim Industries
2" Drop Coil Springs made by Belltech
Rear:
3" De-arched springs from Aim Industries
3" Drop Block, generic, bought from AutoZone.
Rims are Saleen Style, Front: 18x9 wrapped in 255/55-18, Rear: 18x10 wrapped in 285/50-18.
To get that much drop in the rear, you will HAVE to C-notch the frame. I bought a 6" Ranger notch, and cut it down to about 4.5" inches. I also bought my C-notch from Aim Industries.
And before you notch the frame, you should pull the gas tank, and swap it out with a 2nd gen Sport tank, once you swap out the forward mounting plate, it will fit in the stock location of the 1st Gen tank, and more importantly the fill tube is pushed up a little farther, closer to the top of the tank. If you don't do this, you will break your fill tube your first time out....been there done that.
Ryan
