poolsexpo
- September 19, 2014
- 99 explorer ohv
ok, first off ive searched for hours and days, i cant find what im looking for. i have a 99 explorer 4.0 ohv, 125,000 miles on it. i bought the truck and drove it for about 3 months, during the summer here where it was on average 85 degrees out. about 2 months ago, i got a check engine light, i scanned it, p1405 so i bought a new dpfe sensor. unfortunately, on my way home the old DPFE sensor that was on the truck had blowen a hose, and it blew hot air onto the sensor which then melted and literally torched a penny size hole in my intake (plastic upper) manifold. i limped it home, changed sensor, went and got silicone tubing and changed it, i also sealed the hole by getting a piece of thin metal. i used a epoxy good for high heat and plastics. i layered it on intake, then stuck the metal on it, let it dry, then layered over the whole thing again to give it a extra seal. reset computer by disconnecting battery, all was good for about 3 weeks. then engine light again, this time the so delightful lean codes on bank 1 and bank 2, i think there 1071 and 1074. i cleaned maf, new air filter, checked iac and cleaned it, cleaned pcv valve, changed spark plugs since i thought maybe old plugs sucked. reset computer using same method as before. all was great, for 7 days. low and behold, same codes again. i seafoamed motor, used 3 cans of car cleaner spraying all around motor, didnt notice even the slightest rpm change. i replaced fuel filter and gas cap, still no success. i know there are several things i didnt mention to check for when this occurs, im not done just yet. since the day i bought the truck, i noticed it takes about 5 seconds for it to start when cranking first thing in the morning, after that its good any time of the day, only when it sits for a matter of several hours. so theres suspicion number 1. also, i had drilled 10 1/2" holes around the side and back of airfilter box, the bottom section of the box, not the part maf mounts to. i did this for better air, it helped some but could this cause unmetered air? i thought it would have zero to do with it since its before the maf sensor. then today, when the truck started, it hesitated and sounded like it was dieseling for aout 8 seconds before engine idle went up and smoothed out. if i build a smoke machine, where do i inject smoke on motor?
