Im needing help mating up a v8 1996 explorer engine harness at the square plug to my 88 bronco ii harness | Ford Explorer - Ford Ranger Forums - Serious Explorations
bf750
Ky
1996 limited
donalds
Location
Stem
Nc
1999 ford explorer sohc
410Fortune
Truck Season!!
Staff member
Moderator
NORTH IDAHO, 7B
B2 "Slightly" Modified
Callsign
FOURTEN
Seriously?
Like walk you through every wire? That’s is not how this works
First you need to get the wiring info for the c115 from a 96 5.0
Then you need to identify the needed wires on the truck side of things, 1988 bronco ii wiring book a good idea
The alternator charging harness and starting harness as well as wiring to the fuel system are not all included in the c115 plug there are lots of other wires to sort out as well
I can help with some of the specifics but there is no chart or instructions for this
Every swap is different so it would be dang near impossible to just make a “wiring guide”
In my signature you can see my bii 5.0 conversion my bronco ii was converted ti a 93 4.0 ohv wiring before I went 5.0 so it will be quite different
bf750
Ky
1996 limited
I got everything I need.but I need the pin out on the square pug
410Fortune
Truck Season!!
Staff member
Moderator
NORTH IDAHO, 7B
Callsign
FOURTEN
Okay
It’s called c115 on 5.0 explorers 42 pin plug let me see if I can find the pin out
410Fortune
Truck Season!!
Staff member
Moderator
NORTH IDAHO, 7B
Callsign
FOURTEN
This should help
You can do a google search for explorer 5.0 c115 and lots of info comes up
Somewhere on this forum there is a complete spreadsheet for this too
410Fortune
Truck Season!!
Staff member
Moderator
NORTH IDAHO, 7B
Callsign
FOURTEN
