rocket, I don't you are being a jerk. I don't mind critism if its in the right frame of light. I can't dish it out if I can't take it.
Now for my PCM setup the only thing I had the tunner shop do was remove all the trans functions so the engine wouldn't stall to shift gears and not leave my MIL on like a nightlight. He reflashed the PCM, I dont have a chip.
As for the FRPS catalog we agree to disagree.
When someone states good low and mid-range power I expect it not to loose torque and hp at those points. To me low is 1500 and midrange is up to 4000, with 4000-6500 being the high end. The statments just don't agree with the performance.
For the 4.6 and 5.4 2 valves all using the same cam thats something I want to check at work. I can understand if the 4.6 in the Explorer, F and E series all use the same cam. They need to move alot of mass down the road and/or pull a heavy trailer. I honestly can't see the 4.6 for the Mustang using the same cam. The customer expectations between the two are not the same and the comparrison of the 5.0 to the 4.6/5.4 are still valid because no mater if an engine is a 4.6 2V or 5.0 the cam is the mecahnical computer of the engine and will determine the poweband of an engine. The 4V are a different animal and have to rev higher to reach max power.
I will ask hte tunner about what modifications can be made to the calibration. '98-'01 Explorers have the Mechanical Returnless Fuel Systems (MRFS) and not the Electronic Returnless with a FPDM. There is no way to change the voltage to a MRFS fuel pump.
One last thing is I plan to install some Gt40X heads this winter and when i have it all apart i will check the cam timing on hte sproket and at the cylinder to make sure i did it right. If I made a boo boo i'll be the first to admit it
I'll watch your video later. Did you use a digital camcorder? I have an 8mm Hi-Fi and i wish I could convert them to digital to show you my stuff as well
