  • We are aware of the issue with our internal search engine and we will be bringing it back online shortly. For now please use the Google search bar near the top of each page. Thanks, Rick
in dash reciever for 03 sport trac
rurso684
Long Island New York
2003 SPORT TRAC XLT
Im trying to find a in dash reciver for my 03 sport trac. why does crutchfield say none of the touch screens fit it? is there a special mounting kit i need to purchase? is the opening not deep enough? the one i am looking at is the Pioneer AVH-P3100DVD. does anyone else have this problem when looking for a touch screen face?
Also if i buy the clear corners but keep the amber light bulb in, will the corners still show clear when im not using the blinker? or do i need to change the color of the blinker light alsoto white??
steventadams
New Jersey
2001 Sport
Crutchfield thinks nothing fits because the explorers don't have a full double-din opening. Explorers have something like 1.5 din. Not exactly sure what your bezel looks like but on second gen explorers with a little shaving of the plastic bezel the opening can be widened to fit a regular double-din unit
rurso684
2003 SPORT TRAC XLT
bezel? is that the rim around the deck your talking about?
steventadams
New Jersey
2001 Sport
Yea its the plastic thing that surrounds the radio and all of the switches/knobs around the radio. If you pull your radio out there will be a big hole in the middle of it and thats the opening you have to enlarge
rurso684
2003 SPORT TRAC XLT
nice sounds good. i thought it was because it was gonna stick out too much and now push all the way in. i didnt know it was a width issue of the hole.
steventadams
New Jersey
2001 Sport
Also, as far as I know the actual bulb itself has to remain amber. I believe it is illegal for your front turn signal to be any other color.
rurso684
2003 SPORT TRAC XLT
so would it change the yellow apperance if i got the "clear corners" when i leave the amber bulbs in? or would it stay the same?
P Cruise Control Dash Light bulb replacement 2001-2005 Explorer Sport Trac 2
N 01 TRAC dash harness swap, EAVC, info center, RKE 2001-2005 Explorer Sport Trac 2
J 2001 Sport Trac tail lights & dash backlight not working, no bad fuses 2001-2005 Explorer Sport Trac 3
D Dash Temperature Gauge 2001-2005 Explorer Sport Trac 1
M Dash Guage Issue with Battery Indicator 2001-2005 Explorer Sport Trac 3
T No heat from dash on defrost 2001-2005 Explorer Sport Trac 0
R Fancy Ford In Dash Radio RZ5984LP Possible for 2002 Explorer Sport Trac? 2001-2005 Explorer Sport Trac 8
G dash bulbs 2001-2005 Explorer Sport Trac 7
D electric short in dash 2001-2005 Explorer Sport Trac 1
D Dash gauges, windows and radio randomly stop working. 2001-2005 Explorer Sport Trac 2
01Strac painting dash 2001-2005 Explorer Sport Trac 3
G 03 Sport Trac Parking brake and dash lights 2001-2005 Explorer Sport Trac 1
W Electrical dash flicker 2001-2005 Explorer Sport Trac 6
M Question, half of the dash lights are out 2001-2005 Explorer Sport Trac 6
P How do I find the proper fuse for the "(ABS)" dash light on my 04 Explorer Sport Trak 2001-2005 Explorer Sport Trac 4
2 LED Dash board light replacement, need part numbers 2001-2005 Explorer Sport Trac 6
B Dash Lights 2001-2005 Explorer Sport Trac 2
L Brake light on dash issue 2001-2005 Explorer Sport Trac 1
S 2003 Sport Trac dash lights replacement 2001-2005 Explorer Sport Trac 5
B removing the dash 2001-2005 Explorer Sport Trac 1
O dash lights HELP! 2001-2005 Explorer Sport Trac 3
S 02 sport trac dash wire diagram? 2001-2005 Explorer Sport Trac 3
A 05 sport trac dash noise (vacuum leak) 2001-2005 Explorer Sport Trac 3
A replacing dash bulbs 2001-2005 Explorer Sport Trac 2
B changing dash and window switch lights 2001-2005 Explorer Sport Trac 3
D Led on dash 2001-2005 Explorer Sport Trac 6
S 4WD dash switch does not appear to be working 2001-2005 Explorer Sport Trac 16
T Need height of 2" Hitch reciever 2001-2005 Explorer Sport Trac 2
P bumper v/s reciever hitch 2001-2005 Explorer Sport Trac 7
R will this touch screen reciever fit??? 2001-2005 Explorer Sport Trac 3
5 04 sport trac vs ranger 98-11 bumper 2001-2005 Explorer Sport Trac 8
I Need jack assembly for 03 Ford Explorer Sport Trac XLT 4x4 2001-2005 Explorer Sport Trac 2
C 2002 FORD EXPLORER SPORT TRAC 2001-2005 Explorer Sport Trac 1
D 2005 Ford Explorer Sport Trac V6 4.0 Auto 5R55E 2001-2005 Explorer Sport Trac 0
M Ford Explorer Sport Trac Lean 2001-2005 Explorer Sport Trac 1
I 03 Ford Explorer Sport Trac XLT. Sub and amp factory style only 2001-2005 Explorer Sport Trac 2
M 03 Ford Explorer Sport Trac 2001-2005 Explorer Sport Trac 0
H Front rotors replacement 2005 Sport Trac 2001-2005 Explorer Sport Trac 3
S Sport Trac Engine Swap 2001-2005 Explorer Sport Trac 3
S Sport Trac Jr. engine,body bush,Manual Tran.....quest... 2001-2005 Explorer Sport Trac 62
D 05 sport Trac 4.0 won’t shift down 2001-2005 Explorer Sport Trac 0
D Rear differential swap. What will work for 04 sport trac 4.10 gears? 2001-2005 Explorer Sport Trac 9
T 05 Sport Trac XLT squeak. Is this because of a bad harmonic balancer? 2001-2005 Explorer Sport Trac 0
D New member..My 01 Sport 4x4 hunting rig 2001-2005 Explorer Sport Trac 1
D 2005 explorer sport trac driver side power seat limited travel for and aft. How do I make it go all the way forward? 2001-2005 Explorer Sport Trac 1
I 03 Ford Sport Trac XLT 4 Door 4.0 4x4 power mirrors not working 2001-2005 Explorer Sport Trac 1
N 03 Sport trac long cranking. 2001-2005 Explorer Sport Trac 15
B '04 sport trac 4.0 4wd front axle torque spec 2001-2005 Explorer Sport Trac 0
R 2004 Ford Explorer Sport Trac battery losing charge 2001-2005 Explorer Sport Trac 1
C 2001 Explorer Sport - Rear End Vibration 2001-2005 Explorer Sport Trac 2
Similar threads
