02tracNH
- September 26, 2020
- someplace
- 2002 sport trac
I'm at a total loss! I would greatly appreciate any assistance you could possibly give me.
I have everything loose, the rack moves side to side just fine and rotates somewhat depending on what it hits, I even lowered the drivers side lower control arm, in desperation I even cut off the inner tierods to make the whole thing shorter.. but the fing thing just isn't even close to coming out, the end with the shaft looks impossibly too big to fit through the crossmember hole.
is it supposed to come out through the crossmember hole on drivers side? or somehow push through one hole and swivel out from the inside of the crossmember?
or do I Just burn the truck to the ground and go on a hunt for the engineer that designed this? The truck is 2002 sport trac.
Here is a photo of where I'm at: 20200926_165400.jpg
