King$nake
- May 19, 2006
- Oceanside, CA
- 1998 Eddie Bauer 5.0
Ok, so I removed the (2) upper bolts, disconnected the fan shroud, removed the trans cooler lines. The radiator is loose, and seemingly ready to pull out, but the condensor is attached to it. I've pulled one screw out (top-left) that connects the condensor to the radiator, but I cant figure out where it is still connected? I need to remove the condensor from the radiator to pull the radiator out
thanks
thanks
