Because of some future rear suspension modifications I'm planning out, I'm looking into this as a possible solution. I know some people have used the Bronco 2 tank, some the E-150 tank, and I'm sure some other tanks have been used as well. I haven't found all the info I'm looking for, and I have a few thoughts/concerns, so here goes.
Anyone in California done it on a street-driven Explorer, and have you had good or bad experiences with smog checks? Any issues using a tank from an OBD1 vehicle in my OBD2 vehicle? It's very important to me to be able to do a regular smog check without worry. Mechanically I would use all stock smog equipment, but visually there's the potential for failure.
I know some people have done it with a body lift, or say that rear floor modifications are required. Aside from some minor cutting that may be necessary for the fuel filler, I do not want to cut into the floor in the trunk area.
How is clearance to the rear axle once the tank is mounted? I plan to relocate my rear axle 2-3" further back so I'd like to know that there's enough room to do so. Stock shock mounting location is not a concern obviously with the axle moved back.
I've seen pictures of an E-150 tank in place on a 2" body lifted Explorer, and the tank barely hangs below the frame. I do not have a body lift, so it would hang lower for me, but I think a stout skid plate would solve for that.
