shaker1
- March 6, 2003
- Algonquin, IL
- 2006 Explorer XLT 4X4 4.0
I have a Pioneer AVIC F900BT and am preparing to connect it's wiring harness to the OEM (non premium stereo) plug via a Scosche FD23B harness adapter. The color codes on the Pioneer are a direct match for the Scosche harness adapter.
The Pioneer has a pink "vehicle speed sensor wire" and the Scosche harness has a (yet unidentified ) pink wire also. Is the pink wire on the Scosche harness the correct one for the vehicle speed sensor?
In other words, is there a corresponding wire in the OEM Stereo harness that goes to the VSS signal at the PCM (pin #1 purple/orange). Or do I need to run the Pioneer wire to the PCM 50 pin plug directly?
Also, there is a green wire that is supposed to go to the parking brake. I assume to prevent using the DVD while moving. Does this wire receive GRD when the parking brake is applied?
