SCMark
- March 28, 2009
- Anderson, SC
- 1997XLT
One of my injector sockets for the bottom end of the fuel injectors is damaged. These are the hard rubber inserts that go into a bore in the head at each intake port, and lock the lower end of the fuel injector into the head. I had a leak due to the o-ring at the fuel rail end of the injector gone bad, and sprayed fuel onto the top of the engine. The socket insert softened up do to being soaked with gas (figure that - a fuel system component deteriorating from exposure to gasoline) and some of it broke off when I pulled the injector out. Any ideas on where to get replacements?
