adionne 93 XLT 4.0
- June 9, 2000
Hey All, Last weekend I replaced my upper and lower intake manifold gaskets and valve cover gaskets,thermostat while in there. Cleaned the fuel rail, exhaust manifold, valve covers etc. Injectors: the injectors O-rings looked okay but the dust boot (black rubber seal) was showing cracking on a few and two boots were somewhat melted. I was going to have the injectors cleaned at a shop to spray them out with concentrated chemicals etc and re-use. However two things: One they tested the injectors with an Ohm meter?? and said they would recommend replacing the injectors. Also, they cannot clean unless on the vehicle. Keep in mind I have my rig apart in my garage. Second, with the idea of having the injectors cleaned I would buy new dust boots-However I have found I cannot buy the boots by themselves from Ford nor anywhere. I have to buy a new injector to get a new boot. With all this in mind I will be purchasing new injectors from Ford and putting my baby back together this weekend. I have 140K miles. Anyway, I thought to share the info on the injector boots with you from what I have found. If you don't already know!
AL
AL
