INLET MANIFOLD T-PIECE AIR HOSE | Ford Explorer - Ford Ranger Forums - Serious Explorations
glenn_a
Sydney
97 XLT
Hello fellow explorers, just need ur help to find what do u call with this #part or if you have the part number will be good easy for me to google it. its located under the inlet manifold connecting 'Idle Air Control' (IAC) valves... [Gen 2 V6 SOHC] thanks!;)
[/URL]
[/URL]
I don't know but would check how much play there is in the tube up to that point because if there is enough, then you could get a plastic 3-way tee and put short segments of standard rubber hose on all 3 nipples to connect it all back together with hose clamps or stainless wire ties (ebay, if you want to wait weeks for a cheaper delivered price, or an AU seller to sacrifice price for faster delivery).
There probably is some application that uses such a rubber 3 way tee with that diameter, but if you can't get an OEM part # or know of which other applications it is used in (could be anything from industrial to farm tractors) then finding it could be daunting.
thanks! i tried the t-piece but the angle is not that good, i assumed i need a original piece... i am hoping no issue f i disconnect and block it but the idle start to play up time to time...
