Is the packet of red stuff that comes with the Moog inner tie rods lock-tie or grease? If it's lock-tie, should I still go ahead and get some grease to grease the rack up a little before putting the boot back on?
Also, I ordered Moog parts from RockAtuo but one of the outer tie rods had already been opened (looks like it was a return part). The little schrader valve was missing from the packet. But the big thing is, the part is not identical to the other one. Whereas one has a gold metal plate on the top, this one does not. What I'm worried about is that someone stuck a generic tie rod in the box and returned it to Rockauto and they didn't notice. Is there anyway to confirm the part is manufactured by Moog?
Hello,
I'm sorry to hear that part was defective. I'll have our warehouse ship out a
replacement for you tomorrow. As of right now, we will not need you to ship
back the defective part. However, please hold on to it for 2 weeks in case my
warehouse changes their mind. After that time, you may do with it what you
please. I apologize for the inconvenience.
Thank you,
Justin S
RockAuto Customer Service
The large steel clamp is a crush clamp, a special $15 tool makes that tight. Evan used a screwdriver to pry them open/loose. I noticed that he didn't get new clamps with his ends, and used a zip tie to replace the steel clamp. That should work fine, I bought my tie rods from Ford(with clamps), and I had the tool from doing axles prior.
That vent pipe should easily slip or pull out of the boots. Take your time and keep everything clean. Good luck,
