Install help New bilstein's upper single screw spinning
roverz
Bay Area, CA
2000 EB
in the process of installing new replacement bilstein shocks and i installed the two bolts to the lower control arm and started installing the single threaded upper shock mount bolt. Bilstine only supplies one nylon lined nut for this and low and behold there doesnt appear to be any welded nut for me to attach a wrench to to keep it from spinning.
I am sure there is a simple answer here but the shock boot might be blocking a nut or something but i can't feel anything there and didnt want to take the shocks out without a consultation from my EF peeps
roverz
Bay Area, CA
2000 EB
Option #1 Take off the shock and attach two nuts to the bottom of the threaded upper shaft?
roverz
Bay Area, CA
2000 EB
my pos mounty
Land of Corruption
06 F-350
Many times, the top of the shock shaft has a small unthreaded area where you can get a small wrench or a pair of vice-grips on. If it does not, you could do as you already posted and get 2 nuts on the lower part and "cinch" them together for something to grab.
roverz
Bay Area, CA
2000 EB
Finally got hold of Bilstein tech support and stupid me the threaded portition on the top instead of having a flat area like the Motorsport shocks it has an internal allen key that you don't see unless you look down at the threaded stem.
Silly me ok back to install
3 Install/help me install my TMH's? Modified 1995-2001 Explorers 0
M OBX Header Install complete - only issue needing help on Modified 1995-2001 Explorers 25
2 HID install for fog lights need new wiring help mod? Modified 1995-2001 Explorers 0
J brush guard install help Modified 1995-2001 Explorers 14
9 help with oil pressure and water temp gauge install Modified 1995-2001 Explorers 6
B temp gauge install, Help Modified 1995-2001 Explorers 1
S stereo install help Modified 1995-2001 Explorers 3
T Help! 1.7 cobra rocker install Modified 1995-2001 Explorers 7
M Grill Guard Install HELP Modified 1995-2001 Explorers 18
S help help want to install 2004 4.0 into 2000 explorer Modified 1995-2001 Explorers 0
ghosted HELP! EATC Install gone wrong at the relay's Modified 1995-2001 Explorers 0
4 electric fan install HELP! Modified 1995-2001 Explorers 0
B Drawtite Hitch on 98 Explorer, HELP with install please Modified 1995-2001 Explorers 5
R Help.... want to install a Message Center Modified 1995-2001 Explorers 4
K Help. Fuel Pressure gauge install Modified 1995-2001 Explorers 1
T HELP!!!! X-Spec install!!!! Modified 1995-2001 Explorers 9
D AAL Install...Please Help Modified 1995-2001 Explorers 1
T Need help w/ 5.0 Flowmaster catback install Modified 1995-2001 Explorers 3
B How to install a amplifier in a 2nd gen Modified 1995-2001 Explorers 0
M Flash To Pass not correct after LED headlight install Modified 1995-2001 Explorers 0
donalds Supercharger install Modified 1995-2001 Explorers 187
K is possible install wheel hubs Ranger 98 in Explorer 98 to convert manual locking Hubs Modified 1995-2001 Explorers 6
Andrew Bagwell Rough Acceleration after header/exhaust install Modified 1995-2001 Explorers 5
3 Lowering via TT/blocks and TMH install - which one first? Modified 1995-2001 Explorers 1
96ex5.0 OBX header install Modified 1995-2001 Explorers 23
O My partial Explorer Express supercharger kit install Modified 1995-2001 Explorers 17
J One way to install a better seat in the explorer Modified 1995-2001 Explorers 0
B Suspension overhaul and torsen install Modified 1995-2001 Explorers 3
M A/C Evaporator Fan Install Modified 1995-2001 Explorers 2
A How to install mechanical oil pressure gauge in a 98 Merc Mountaineer 5.0? Modified 1995-2001 Explorers 3
R 5.0 Manual Trans Install Modified 1995-2001 Explorers 1
G EGR tube install write up with pictures Modified 1995-2001 Explorers 2
J what other years on i install my 99 engine Modified 1995-2001 Explorers 1
J How to install a second battery for electronics? Modified 1995-2001 Explorers 1
W How to install fog lights on XLS? Modified 1995-2001 Explorers 1
M Saleen Wing install instructions Modified 1995-2001 Explorers 5
D Squeaking after war153 install Modified 1995-2001 Explorers 10
Greg_DonWindsor Wiring questions for electric fan install Modified 1995-2001 Explorers 9
M Saleen XP8 Hood and Spoiler home - next step paint & install on Big Whit Modified 1995-2001 Explorers 49
M Saleen XP8 Rear Swaybar back fresh from Powder Coat - ready for install on Big White Modified 1995-2001 Explorers 8
P Electric Fan install 1997 ford eplorer 4.0 OHV Modified 1995-2001 Explorers 3
6 How to install Spyder CCFL headlights Modified 1995-2001 Explorers 6
M Grill Guard Install Modified 1995-2001 Explorers 7
A Anyone else install an hourmeter? Modified 1995-2001 Explorers 5
D The Wrong Way To Install an Aussie Locker Modified 1995-2001 Explorers 3
W Tow Hook install on 1997 Mercury Mountianeer Modified 1995-2001 Explorers 14
Greg_DonWindsor HID foglight install with pictures. Modified 1995-2001 Explorers 9
9 AAL and Warrior shackle install..any pointers? Modified 1995-2001 Explorers 5
1 Looking to install a Safari Rack on my Ex… Modified 1995-2001 Explorers 6
Greg_DonWindsor Finished custom stereo install, stealth sub box and amp locations Modified 1995-2001 Explorers 14
Similar threads
