RammaR
- August 21, 2001
- Franklin, TN
- '96 XLT 4x4
I've got a '96 4x4 with a 45 axle code (3.55 open). I also have 31x10.50's and the TT/shackle lift, which changed the gearing a bit. I'd like to improve my 4x4 traction with either installing a L/S or locker. I'd also like to go to 4.10 gears to get back to a better overall ratio. But swapping the ring & pinion seems to be a major project and I might be better off looking for a set of D2 diffs (4.10 L/S) and doing a whole swap.
My questions are:
1) Does the factory D2 front axle also have a L/S or is it just in the rear?
2) Swap the whole axle or just the diff's?
3) What are some things to look for or stay away from when hunting for used axles / diffs?
Thanks for the advice.
My questions are:
