Installed lowering keys... now leans to the right
Kingt816
2000 ford explorer
Just finished lowering my '00 ex 3" in the front (which yes it's an awd and yes I know that will prematurely wear my cv joints) but the problem is now I have to turn the wheel almost a quarter turn to the left to drive in a straight line. I was just wondering if anyone has a reason as to why this is and any quick fixes to this problem; other than raise it of course
Thanks
vroomzoomboom
Elite Canuck STOCK SUCKS!
selkirk, manitoba
98 supercharged 347 sport
you need to do a alignment after dropping or lifting them because you have changed the geometry of the suspension
Kingt816
2000 ford explorer
Update on the situation:
I knew all along I'd need to get camber kits for both sides, but I can't wait for them to come in the mail. A friend of mine's dad told me that if I were to get the tie rods shortened this would fix my camber issue; does anyone have any idea if this would actually work? I'd rather have that done in a day or two than wait weeks for parts to come in the mail, even if it is more $$
corkey
Moderator Emeritus
Moderator Emeritus
Location
Sioux Narrows Canada
Elite Canuck,multiple ifs offender,, and musky maniac,, i wheel and i fish,,
99 xls,96 xl,91,08 Ranger
the kits are the way to fix the alignment, you move the upper control arms for camber , not the tie rods
tie rods you adjust, they are the length they are cause in the cycle from the bottom of the suspension travel to the top of the travel they only need to be adjusted a small amount to maintain proper toe,,
E Canuck Motorsports lowering springs installed Lowered Explorer - Ranger Suspension Tech 0
I X-Spec Lowering Kit Installed... Lowered Explorer - Ranger Suspension Tech 16
J (Dropped X's) Camber after cam bolt kit installed??? Lowered Explorer - Ranger Suspension Tech 3
C Lowering my 91 explorer Lowered Explorer - Ranger Suspension Tech 0
B Lowering torsion bar HELP Lowered Explorer - Ranger Suspension Tech 13
B Lowering blocks install question Lowered Explorer - Ranger Suspension Tech 3
M Lowering 2nd Gen - Front Bump Stops Question - also shocks ? Lowered Explorer - Ranger Suspension Tech 1
M Lowering 2000 Limited with rear air supension - Ride Height Calibration Question Lowered Explorer - Ranger Suspension Tech 0
S Lowering 2000 explorer Lowered Explorer - Ranger Suspension Tech 2
N Lowering 04 Explorer 4x4 Wagon Lowered Explorer - Ranger Suspension Tech 4
R Lowering Shackles Lowered Explorer - Ranger Suspension Tech 12
1 Advice needed about lowering blocks! Lowered Explorer - Ranger Suspension Tech 6
L Lowering a 2007 Explorer Lowered Explorer - Ranger Suspension Tech 0
J 98 explorer sport lowering blocks question Lowered Explorer - Ranger Suspension Tech 1
H Details on lowering kits for my 99' Mercury Mountaineer Lowered Explorer - Ranger Suspension Tech 5
8 lowering kits for 2nd gen explorers? Lowered Explorer - Ranger Suspension Tech 5
D Lowering quick struts. Lowered Explorer - Ranger Suspension Tech 1
R 02 XLS Lowering for performance, not looks. Lowered Explorer - Ranger Suspension Tech 0
S Lowering the front end. Lowered Explorer - Ranger Suspension Tech 2
9 1st gen x lowering help Lowered Explorer - Ranger Suspension Tech 2
A lowering the 2nd gen 4x4 Lowered Explorer - Ranger Suspension Tech 4
J Lowering my Explorer. Lowered Explorer - Ranger Suspension Tech 6
S lowering front and back w/ a week in between. Lowered Explorer - Ranger Suspension Tech 0
A Lowering Explorer Lowered Explorer - Ranger Suspension Tech 1
F lowering factory control arms? Lowered Explorer - Ranger Suspension Tech 7
A 01 lowering kit????? Lowered Explorer - Ranger Suspension Tech 8
DeadlySteve Lowering Gen 1 4x4 ... Lots of Q's! Lowered Explorer - Ranger Suspension Tech 3
S Lowering an 05 AWD V8 Mount Lowered Explorer - Ranger Suspension Tech 1
U Lowering a 98 Mounty 5.0 AWD. Any help appreciated! Lowered Explorer - Ranger Suspension Tech 3
F need help lowering a 1997 4x4 Lowered Explorer - Ranger Suspension Tech 4
D Lowering a 2001 Sport Lowered Explorer - Ranger Suspension Tech 8
F lowering ?s Lowered Explorer - Ranger Suspension Tech 8
P Lowering via Torsion Twist Questions. Lowered Explorer - Ranger Suspension Tech 3
O Lowering my 99 Sport Explorer. Lowered Explorer - Ranger Suspension Tech 2
T Lowering my 00' Mounty. A few questions... Lowered Explorer - Ranger Suspension Tech 7
R please help! lowering 06 explorer/mountaineer Lowered Explorer - Ranger Suspension Tech 4
9 New Sticky Needed :TT Lowering the front Lowered Explorer - Ranger Suspension Tech 1
O Will I need an alignment after lowering blocks? Lowered Explorer - Ranger Suspension Tech 4
D Lowering first Gen Explorer. Lowered Explorer - Ranger Suspension Tech 28
O Lowering blocks...what is the actual drop? Lowered Explorer - Ranger Suspension Tech 3
R Lowering 2002 XLT Lowered Explorer - Ranger Suspension Tech 1
O Lowering 2003 Ford Explorer Sport 4WD Lowered Explorer - Ranger Suspension Tech 5
B Lowering keys Lowered Explorer - Ranger Suspension Tech 34
A lowering first gen 4x4? Lowered Explorer - Ranger Suspension Tech 11
B Finally the time has come.... lowering. Lowered Explorer - Ranger Suspension Tech 5
M Lowering a 3rd Gen Lowered Explorer - Ranger Suspension Tech 4
M some info on lowering Q's about ranchos Lowered Explorer - Ranger Suspension Tech 7
Turdle Lowering a 95-01 ( torsion bar front) explorer Lowered Explorer - Ranger Suspension Tech 8
4 93 bauer 2wd Lowering question Lowered Explorer - Ranger Suspension Tech 1
M Help with lowering 97 Monty AWD Lowered Explorer - Ranger Suspension Tech 2
Similar threads
