Installed new blend door actuator - Still no heat | Ford Explorer Forums - Serious Explorations
Seanm0918
SF
So I spent all day on doing this. I made sure it was the right part put it in, air blows cold still. Does that mean it is the door itself? I dont hear anything when I switch from cold to hot on the dash. Thanks
2004 Explorer v6 btw.
if it is anything like the gen 2's you can pull off the electric actuator motor to verify it is rotating when the dial is turned from hot to cold.
You might also check the coolant level and for heat on the inlet hoses going to and from the hvac plenum under the hood.
