bigtigexplorer
- March 26, 2001
- Sierra Vista, AZ
- '99 XLT 4x4
My factory springs were sagging pretty bad. With no load the springs were flat, with my trailer hooked up, a 18' BigTex 70DM the springs had a negative arch. So I ordered a set of custom leaf springs from Carrier Spring a heavy
duty version of their 2 inch lift springs.
The new springs appear identical to my stock springs with the exception of an additional lead in thethe pack. In a side by side comparision the new leafs were only about two inches taller than my worn out stock leafs, I kind of expected a bigger difference. After installing the new leafs, they look almost as flat as my stock leafs were.
I do have a set of warrior shackles, and I know the shackles tend to flatten out your springs. Should I remove the shackles and put the stock shackles back on?
Thanks
Thanks
