94Eddie
- September 18, 2003
- 2010 Mountaineer Premier
I have heard here many times that replacing old plugs with new ones makes a big difference in how the engine runs. I thought this was said mostly due to the mind feeling improvements that weren't as drastic as what really occurred. I am almost sure the plugs I pulled from the engine today were the originals from the factory. Several had the center electrode worn down to the point the gaps were close to a 0.1" wide which is more than twice the factory spec. They most likely had around 120k miles on them. Well I am a convert because the difference in how the engines now runs is somewhat unbelievable. Idle is smooth as glass and I swear that throttle response is also much better. I am curious to see if gas mileage improves noticeably. Fortunately none of the plugs showed any signs of running rich, lean or burning oil.
So I am now preaching the gospel on the benefits of replacing plugs that have seen many miles. At least for the 4.6L 3V engines. Next up is my 2007 Mustang. It has 60k miles on it and I doubt the plugs have ever been changed. It should probably be done soon to minimize the risk of breaking a plug. I am not looking forward to this nerve racking plug change.
