instrument cluster light bulbs???
rockey95
Mississippi
I've got a 2010 Ford Explorer XLT 2WD and i had a light go out behind my gas gauge in my instrument cluster. i've got to all my local shops and no luck, i can order them thru the Ford Dealership here but just wanted to see if anyone else have ordered these thru other websites. On the back of my bulb housing it says 12V 1.5W Osram and the bulb sits in this little housing and it screws into the instrument cluster. Any help would be appreciated.
Thanks
michael623
Fremont, CA
2006 Ford Explorer XLT
Thanks
I have an 2006 Explorer XLT and needed to replace a cluster bulb as well. Found this part on Amazon and even though the listing says its for BMW, it was a match to the part I pulled out. This might be the same for your 2010.
https://www.amazon.com/gp/product/B00D03YYUG/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
94Eddie
2010 Mountaineer Premier
I just replaced a burned out instrument cluster bulb in my 2010 Mountaineer. It was very easy to do. Take out eight easy to locate screws, disconnect two electrical sockets and the whole cluster comes out. I replaced all the bulbs in mine since they are very inexpensive to buy from Amazon. I used the bulbs Michael referenced. The video linked below shows how easy it is to remove the cluster.
S Instrument Cluster Light Stock 2006 -2010 Explorers 0
Y 2007 Instrument Cluster Stock 2006 -2010 Explorers 2
S 2006 Explorer 4.0. PCM/instrument cluster replaced/programmed but the dreaded wrench icon is lit Stock 2006 -2010 Explorers 42
P 06 xlt instrument cluster failure Stock 2006 -2010 Explorers 0
J Instrument Cluster replacement? Stock 2006 -2010 Explorers 3
Z Swap Instrument cluster - help Stock 2006 -2010 Explorers 1
P I hate my white instrument cluster. What can I do about it? Stock 2006 -2010 Explorers 6
M 2006-2010 Instrument Cluster Removal Stock 2006 -2010 Explorers 5
J Instrument Cluster Malfunction Stock 2006 -2010 Explorers 5
E Optional Instrument Cluster Stock 2006 -2010 Explorers 3
B instrument cluster upgrade Stock 2006 -2010 Explorers 3
T Removing The Instrument Cluster Stock 2006 -2010 Explorers 5
L Instrument cluster bulbs replacement Stock 2006 -2010 Explorers 11
P Instrument Cluster Bulbs Stock 2006 -2010 Explorers 10
G Instrument cluster problem Stock 2006 -2010 Explorers 9
X Instrument Cluster Stock 2006 -2010 Explorers 4
A Instrument cluster swap Stock 2006 -2010 Explorers 2
A Replacing instrument panel Stock 2006 -2010 Explorers 5
E 2010 explorer xlt instrument lights fix Stock 2006 -2010 Explorers 2
C No Instrument indication and will not start Stock 2006 -2010 Explorers 5
B Instrument bulb replacement tutorial. Stock 2006 -2010 Explorers 7
P 08 LTD. changing Instrument panel bulbs requires "programming"??? Stock 2006 -2010 Explorers 11
M Instrument Panel Issues Stock 2006 -2010 Explorers 3
X Instrument Clust Light Burnt Out Stock 2006 -2010 Explorers 4
M Instrument Panel Lights Stock 2006 -2010 Explorers 13
T 2006 cluster/interior lights dimmer switch ***SOLVED*** Stock 2006 -2010 Explorers 13
B Dash cluster 06 mountaineer Stock 2006 -2010 Explorers 0
M Cluster shutdown while driving Stock 2006 -2010 Explorers 0
W Gauge cluster Stock 2006 -2010 Explorers 0
A 09 Explorer no start - RSC Service now, Theft light blinking, gauge cluster dead Stock 2006 -2010 Explorers 12
B 2007 Explorer v6 (no cluster lights on & no start) Stock 2006 -2010 Explorers 6
B Cluster swap? (Ex to Mounty?) Stock 2006 -2010 Explorers 6
M cluster problem Stock 2006 -2010 Explorers 0
8 Gauge Cluster Plexi glass Stock 2006 -2010 Explorers 9
B 4 Line Cluster Stock 2006 -2010 Explorers 6
MustangP51 Different color screens in gauge cluster? Stock 2006 -2010 Explorers 4
H Anybody know how to take the Gauge cluster apart? Stock 2006 -2010 Explorers 5
Y 07 Explorer Traction control light on! Stock 2006 -2010 Explorers 2
E 2010 Explorer XLT Service wrench light and no TC lock up Stock 2006 -2010 Explorers 2
B wrench light at 5500 rpm Stock 2006 -2010 Explorers 8
F 06 lurching in drive & Trac. light Stock 2006 -2010 Explorers 5
K Check engine light on and can't pass emissions.... Stock 2006 -2010 Explorers 10
V Steady Airbag light on after aftermarket stereo install Stock 2006 -2010 Explorers 8
A 2006 Ford Explorer 4.0 2wd oil pressure light comes on at idle Stock 2006 -2010 Explorers 5
G Wrench Light, Code PO713 Stock 2006 -2010 Explorers 1
T Dome light staying on question Stock 2006 -2010 Explorers 3
D Cruise control light not working Stock 2006 -2010 Explorers 2
K Locked up - ABS light, parking brake light, air bag light, traction control light on. Stock 2006 -2010 Explorers 3
G 2010 Eddie Bauer Interior LED light replacement Stock 2006 -2010 Explorers 2
B Tire Fault Sensor Warning Light Stock 2006 -2010 Explorers 10
Similar threads
