NPGuy
- December 5, 2015
- North Pole alaska
- 1991 Ford Explorer Eddie
I have a 1991 and am wondering if anyone has had any issues with their tach reading high? I don't have an external tach yet to compare it to but am thinking it is reading high.
I followed the procedure for resetting my idle after doing a bunch of work to the car and it still shows on the dash that it is idling just over 1,000 Rpms. It is nice and smooth and steady. I am planning on buying a photo tach to measure it with.
I had the dash apart to replace all the lamps and looked at the tach at that point. And cleaned up the connections and sprayed the needle shaft with some electronics cleaner lube.
Has anyone ever had to replace any of the components on the little PCB? I did find some videos on re soldering some of the components on the board for newer instrument clusters that had cold solder joints.
Any one?
Any one?
