CrAzEd412
- June 12, 2007
- Berryville,VA
- 96 Explorer XLT 4.0L 4wd
Hey all,
I've been searching for a little while now and have come up empty handed so far. My instrument panel has more then one problem. First the tachometer doesn't work at all sometimes it will randomly work other times it wont at all and just sit at zero. What is the problem that could be going on? Loose connection? My other question is the other day while i was shifting into drive the gear indicator seemed to snap and shot the indicator past the 1st gear marking. I am left to moving slowly into overdrive hoping im not in 2nd at times. Is it at all possible to get a new instrument panel from the junkyard or an aftermarket place such as rockauto or partstrain? My other question is since it has the original odometer with it and a new engine is there anyway of swapping that out into the new IP to maintain the correct reading for the body mileage? Any help would be greatly appreciated!
Thanks!
Thanks!
