Hank
- October 19, 1999
- Cape Coral, FL
- '91 EB
Problem started today.
At first could not start the ex, cranked but would not fire.
Checked a plug, wet. Dried it off an put it back in. Waited for a few thinking it was flooded.
Cranked and it started, check engine light on, rough but holding idle. No power, bad smell and black exhaust.
About a min later I hear a deap phew or thump/whoosh may be a better description, cel turns off and truck is fine. Shut it down and start it back up the whole thing repeats but takes longer to come out of funky mode.
Side note here, when turning the key on, but not cranking, I hear the fuel pump running. Not just that 3-5 second priming but non-stop running.
Let it sit for a few hours with the battery cable disconnected and tried again. Same condition but lasted about 10 minutes, then funny deap phew noise and all normal. Let it warm up to normal temp as it is running happy then shut it off.
Turn the key back to on an the fuel pump does its NORMAL 3-5 second prime. Engine starts right up like normal, no CEL. Repeat 3-5 times when warm. All ok. Shut it off for the night.
Note, NO CODES being thrown when initiating an EEC test.
Checked the vac. tree and lines, all look ok.
Confirmed normal operation, voltage, resistance and proper movement under power, of the Idle Air Control valve, also cleaned it. Ex will stall when in funky condition if I pull the power to the IAC.
Thinking fuel pressure regulator or sticking EGR? What do you guys think?
