Blvdst
- June 4, 2017
- Deephaven, MN
- 2005 4X4 XLT 4.0
My 05 4.0L is intermittently overheating. Radiator has been flushed and new coolant added. New thermostat and gasket. Radiator fins are clean. No signs of a leak. Pressure test was good. New belt and fan clutch. Everthing is fine until it is driven in the city with stop and go traffic for more than 30 minutes. Today it reached the hot level but not at the overheat mark to trip the overheat light. Once the air flows through the radiator at 30 or more mph the gauge will drop to the normal level which is one tick below the midway pont. I'm thinking it needs a water pump since it will cool down if air gets to the radiator. If you have had a similar problem with yours I'd like to hear how you resolved it?
