jimbolin
- April 7, 2005
- crosby,texas
- 93 4 door
93 4.0 no codes.Will run fine for a few days then it will run rich to the point of just barely running.When it does this the fuel pump will go past prime when key is turned on.I have not been able to find any shorts or wiring problems.The only things I have not changed out is pcm and crankshaft position sensor.Is there anything else that would make it run rich intermittently?When it runs it runs great.
