Is my ECU fried? | Ford Explorer - Ford Ranger Forums - Serious Explorations
Is my ECU fried?
fmaster7
Jackson, NJ
'92 XLT 4x4
Power is getting to the computer and chec engine light does not come on with key turned.
Join the Elite Explorers $20 each year.
Elite Explorer members see no advertisements, no banner ads, no double underlined links.
Willard
Bloomington, Indiana
04 Ranger Edge
If the check engine light doesn't come on at all it may very well be. I am assuming the engine doesn't run. Also, you shouldn't hear the fuel pump run either if the computer doesn't work.
Just make sure it's not the bulb or something to that effect. Just grab another computer from a junkyard if it's fried, new ones are far from being worth the price.
fmaster7
Jackson, NJ
'92 XLT 4x4
brand new fuel pump, fuel pump relay, fuel filter.
Reason i think its fried is because if i bypass the relay, pump comes on, im getting spark...but computer is not controlling the injectors to make it start.
waskly
Crooklyn NY!
does the vehicle have vref? 5v from the pcm, are you powering all the points the relay powers?
fmaster7
Jackson, NJ
'92 XLT 4x4
All i now is the parts of the relays that need power from the ECU are not getting the power they are supposed to get.
fmaster7
Jackson, NJ
'92 XLT 4x4
Just bought a computer off ebay. Should be here in 2-3 days. Will let you know the outcome.
fmaster7
Jackson, NJ
'92 XLT 4x4
What is the wire color that supplies the ECU with power?
snoranger
Jackson, NJ
94 limited on 35's
Is it stick or auto. If its stick, I've got a comp from a 91 you can try.
BTW- where in Jackson are you?
fmaster7
Jackson, NJ
'92 XLT 4x4
Damn its auto. And Harmony Rd. Where you at?
snoranger
Jackson, NJ
94 limited on 35's
waskly
Crooklyn NY!
did you just try to use a 20amp fused wire to power the hot side of the pcm relay off the battery to see if the pcm goes online?
off the top of my head i think it powers 3 pins. or 2, if its a 104 pcm connector.
a fried pcm and offline will not have vref. this is something done in the pcm and its a 5volt signal.
fmaster7
Jackson, NJ
'92 XLT 4x4
no i didnt try that, that would be the brown relay? And whats VREF?
fmaster7
Jackson, NJ
'92 XLT 4x4
New prospect rd.
I'll check to see if I have an auto comp in my collection.
Wow right down the road. My X is actually on Aldrich Rd. right before you get to Howell border. That would be great if you had one laying around.
snoranger
Jackson, NJ
94 limited on 35's
I'll check in the morning.
Im off aldrich.
fmaster7
Jackson, NJ
'92 XLT 4x4
alright thanks, maybe you can text me if you find it.
(number removed) my name is Nick
waskly
Crooklyn NY!
i would pm that info, not post it on a public message board. just looking out for you.
snoranger
Jackson, NJ
94 limited on 35's
Delete your number, I saved it.
