SyberTiger
- May 18, 2007
- Orlando
- 2002 Limited 4x4 4.6L
I'm working on replacing my intake manifold but thought I might as well replace the valve cover gaskets since they are starting to weep. As you can see, below, I removed the passenger side valve cover which exposes the top of the passenger side camshaft sprocket. See the red arrow in the picture...when I pull on the chain outward from the sprocket I notice the chain will pull away from the sprocket about 1/4". On the opposite side of the sprocket the chain is taut. Are both sides supposed to be taut or is it normal for there to be some play where the red arrow is?
