84FLH
- February 14, 2016
- 2000 Mercury Mountaineer
After a slow coolant leak (fill overflow tank once a month) turned into a weekly filling and then smelling coolant in the cabin, I found these areas under hood soaked with coolant:
- top of passenger side shock tower
- top of passenger side motor mount
- transmission lines running across passenger side motor mount, parallel to frame rail
- passenger side of block, near front of motor and under exhaust manifold.
- entire front of engine under water pump, down to/including cross memgber
Local shop said water pump bad, replaced same @ 375, didn't fix leak. Same shop then said heater control valve bad, replaced same @ 133, didn't fix leak. Same shop now says lower T-stat housing leaking. I pulled air intake duct and throttle body, then raced motor by hand. Didn't see any coolant leaking from top or lower T- stat housing but flat area behind lower housing had wet area about 1/2" W x 2" L. Wet area is so small it doesn't seem possible it's source of coolant that's covering the above listed areas.
Had noisy timing cassette replaced 8 years ago (2012) by Ford mechanic. I put about 100,000 miles on since then. The guy was a top mechanic (friend of a friend). I'm thinking he used the correct green Teflon gasket on timing cover, and the job shouldn't be leaking after only 100,000 miles.
Can't figure out how to download smartphone pics to my pc so I can't at this time post pics. Appreciate any advice, suggestions, input from those who've gone down this road before me.
