richardumberger
- January 27, 2016
- Carrollton, GA
- 2002 ford ranger 5.0 4406
Is this cam too big for my stock 4r70w torque converter?
Cam Specs
2,000-5,500
Intake Duration at 050 inch Lift: 221
Exhaust Duration at 050 inch Lift: 225
Duration at 050 inch Lift: 221 int./225 exh.
Advertised Intake Duration: 275
Advertised Exhaust Duration: 279
Advertised Duration: 275 int./279 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.499 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.510 in.
Valve Lift with Factory Rocker Arm Ratio: 0.499 int./0.510 exh.
Lobe Separation (degrees): 112
Camshaft Gear Attachment: 1-bolt
Computer-Controlled Compatible: Yes
Grind Number: HR-224/339-2S-12
Valve Springs Required: Yes
Lift w/ 1.6 rocker (intake/exhaust) - .499"/.510"
Lobe separation (degrees) - 112°
If so can you explain how i go about getting one in the right range please. Im running 4.56 gears with 37 inch tires. I put cam in dot to dot
Cam Specs
2,000-5,500
