Is this normal???
RIKK03
San Jose, Ca
2003 Limited 4X2
At incline, I'm having a hard time putting my 03 Explorer in reverse. It's really hard engaging it and it makes a really hard clunking sound. I had the solineod replaced before. It only happens at incline and wanted to know if anybody else have the same problem. I have an extended warranty.
jimbo74
Elite Exploder
Nor*Cal
2001, F150, XLT 4x4
are you talking about when its parked and you throw it into reverse? that it clunks louder than usual or worse than in forward? as a general note, most vehicles do at least something liek this as reverse is a steeper gear than the forward gears....
my toyota truck is a stick, but it always has more trouble going into reverse than in any forward gear as its internals are trying to redirect power
DeRocha
NEX Vice President
Moderator Emeritus
Brockton, MA
'93 XLT 4x4
Are you using the E-brake? If you don't use your E-brake when you shift into park and ease off the brake peddle the vehicle will roll back and rest against the parking prawl within the Transmission. The steeper the grade the more force against the prawl and the harder it will be for you to shift out of park. The solution is to shift into park (with the brake peddle depressed), set the E-brake and slowly ease of the brake peddle and verify the vehicle does NOT roll. If the vehicle starts to roll depress the E-brake more.
RIKK03
San Jose, Ca
2003 Limited 4X2
Yes...This is fromm Park to Reverse and the steeper the grade, the harder it is to throw in reverse.I guess this is normal for most vehicles. Thanks for the info.
jimbo74
Elite Exploder
Nor*Cal
2001, F150, XLT 4x4
if its resting on the pawl as mentioned above, it is normal... if its a driveway, i have never had any problems with an automatic..... but if its a hill use the ebrake, it could potentially damage the tranny....
neoboy05
Texas
'03 XLS
Aside from the e-brake, which is totally correct btw, I have the same issue. It has been taken to the shop 3 times now for the same problem. In the shop now for the same issue. I dropped it off before going on vacation. The have replaced the tranny fluid/filters, couple of solinoids and the problem comes and goes. My 03 only has 26,700 miles on it. I also had a rear differential whirl which they didn't even try to fix. They replaced the entire rear differential housing which has come back now. So this isn't normal and you should well document it and report it to your dealership. There is service bulletin out on the problem. Just FYI.
Brian_B
Mountain Home, AR
2000 mounty / 56 f-100
I assume some of you guys have rebuilt a few automtics. If you have, you know that parking pawl is very small to be holding the entire weight of our Xs (4800#???). Always using the E-brake is a good habit to get into. I have seen those pawls break from being stressed (maybe over time?) and let a vehicle roll off with no E-brake to hold it. They are there for a reason. Use it!
neoboy05
Texas
'03 XLS
I know all about the parking pawl, and yes I do know it is really small and holds the entire weight of the truck. I didn't deny the use of the e-brake. I can't say I always use it but whenever I park on an incline I do. I figure if the truck rolls back with the e-brake then thats less liability on me. My issue is not with the use of the e-brake. It is an issue with the tranny having issues and clunking even with the use of the e-brake.
BenS
Golden Monkey Addict
Mohnton, PA
1997 Explorer Sport
Do you have a link to the service bulletin for this? Thanks.
neoboy05
Texas
'03 XLS
http://www-odi.nhtsa.dot.gov/cars/problems/tsb/tsbsearch.cfm
For all your recall and TSB needs. :)
FYI, my truck came back from the repairs:
Replaced the rear differential casing for the whirling sound @ 50 to 70 mph.
- They tried to fixed it but ended up ordering a new revision model.
For the tranny (3rd time they do this)
- replaced the control solinoid
- reprogrammed it
- flushed it, new fluid (only 25k) (for the clunking, hard shifts and hesitation)
K 05 Explorer AC not blowing cold: Low side high, high side normal Stock 2002 - 2005 Explorers 2
H Testing normal transmission behavior ? Stock 2002 - 2005 Explorers 7
G Normal anti-theft light battery drain? Stock 2002 - 2005 Explorers 1
R Is this normal defrost operation 02 w/ dual control Stock 2002 - 2005 Explorers 1
E Fuel pressure of 60-66 normal? 4.6L Stock 2002 - 2005 Explorers 7
E Ac cycling about every 10 seconds? Normal? Stock 2002 - 2005 Explorers 1
J Not your normal timing chain question. Stock 2002 - 2005 Explorers 5
K 03 Explorer just lacking normal power when warm. Stock 2002 - 2005 Explorers 17
J Temp gauge going full hot then normal. Stock 2002 - 2005 Explorers 6
N liftgate crack and not the normal one Stock 2002 - 2005 Explorers 0
S Is it normal to hear 4x4 kick on when in Auto mode? Stock 2002 - 2005 Explorers 2
R Is this normal? Stock 2002 - 2005 Explorers 0
B Is this normal Stock 2002 - 2005 Explorers 3
2 What woud you consider normal oil seepage/buildup on the bottom of 155K 2002 4.0 XLS? Stock 2002 - 2005 Explorers 2
T Low oil pressure normal when braking? Stock 2002 - 2005 Explorers 0
C Is this normal movement for the belt tensioner? Stock 2002 - 2005 Explorers 5
D clutches normal wear out part on AWD mounty? Stock 2002 - 2005 Explorers 10
D What are "Normal" Temps While towing Stock 2002 - 2005 Explorers 3
J check advancetrac ... this normal? Stock 2002 - 2005 Explorers 3
0 is this normal Stock 2002 - 2005 Explorers 3
D weird idle sound...vid inside...normal? Stock 2002 - 2005 Explorers 22
S Is this normal with the steering? Stock 2002 - 2005 Explorers 7
K Temperature Gauge spikes for 10 secs, then returns to Normal range Stock 2002 - 2005 Explorers 8
X Normal Gas Mileage? Stock 2002 - 2005 Explorers 29
J Thermostat showing hot just a few seconds then back to normal? Stock 2002 - 2005 Explorers 10
X 4X4 High Noises - Normal? Stock 2002 - 2005 Explorers 0
T Oil Pressure Gauge responds instantaneously. Normal? Stock 2002 - 2005 Explorers 8
J What is the normal coolant temp range? Stock 2002 - 2005 Explorers 5
A AC Issue, is this normal Stock 2002 - 2005 Explorers 6
S Rough idle but not the normal rough idle Stock 2002 - 2005 Explorers 0
R is shifting like this normal on an auto '04 xls 4.0 Stock 2002 - 2005 Explorers 6
Similar threads
