As for the Stale comment, this is true. Its actually part of the vehicles adaptions. Most of the time when you reflash the vehicle, the adaptions are reset. With SCT, the adaptions are reset after each flash. So you dont have to go back to stock and then re-install the tune, just reflash the same tune. This is also true about adaption. If you flash a tune and then drive like a jack butt for the first 50 miles, your trans adaptions and other things will learn those habits and your vehicle may not shift like you want. I always tell people to drive casually for the first 10-20 miles and then go crazy if you want. I used to get calls all the time about harsh shifting and such, and most of the time it was just the customers lead foot after a freshly installed tune, creating adaptions that were unsavory for daily driving. After they get the "must go WOT" out of their system and drive a bit more normal, daily driving and WOT seems to be much better. Also on the XSport, if you are going to be drag racing, do not reflash right before you make a pass. The vehicle has a pre-adaption shift schedule that is really tame/soft and thus your quarter mile times will be slower. It is recommended to do at least 2-3 hard WOT launches after a reflash, or at least drive it 10-15 miles before doing your drag pass to get back to normal shift schedule driving.
