Jon M
- January 12, 2017
- Mount Pleasant, SC
- 2015 Explorer XLT
I had the dealer look at my right front window for the window chatter issue. First, I was told it was "normal". I told them there was a TSB on it, 13-6-13 according to the TSB thread.
They called back and said that that TSB is inactive, but there is another "not-a-TSB", like a TSB, on it, so they ordered the parts.
I don't what the "not-a-TSB" is called, nor have I ever heard of them before, but there you go.
On my power liftgate, which would close most of the way, and then reopen, typically 3 times before it would finally close, there is apparently a TSB. I didn't see one in the TSB thread when I reviewed it, but they say there is one.
Now, I have a question for all of you regarding your A/C's performance. This is my third Ford, and I've driven many others. One thing that I've always known, and heard many others say, is that when it comes to A/C, Ford makes the coldest there is.
On my 2013, when at idle, my A/C is not cold. It's not warm, but it's not cold. It's fine at speed. On every vehicle I've owned, and experienced this, it was due to a failing A/C compressor clutch. The dealer is telling me this is "normal", because there's no air flowing over the condenser at idle.
Freon's full, fans are turning, compressor's running...everything is "within spec". I'm guessing it's probably starting to fail, it's just not bad enough to catch yet.
So, do you all experience this? Or do you have an A/C system worthy of Ford's reputation?
I asked them about activating the hour meter, and they had no clue IF it could be done, much less how, on a non-police vehicle.
