SportEX95
- November 9, 2010
- Seattle, WA
- 95 Sport XLT
Okay, 95 Explorer Sport. 4 Liter OHV engine. Starts but won't keep running with throttle closed. Will run for 3-5 min. throttle open at least half way then slowly dies. Will start again hours later. After cools down plugs wet with gas & carbon fouled. Has low vacuum when running. 40 PSI at fuel rail, stays around 38PSI, 30 min. after key off. Starts easily, almost wants to idle. After running catalytic converter glows red...Disconnected muffler but had no effect on symptoms.
New: Catalytic converter,intake air control valve, coil pack, plug wires, plugs, upper intake manifold gasket, cleaned MAF sensor & Intake air temp. sensor. Have two PCM's both same symptoms. New air filter, oil and filter, new fuel filter.
EGR valve blocked by temporary blocking plate, so not a factor, vacuum line disconnected & plugged as well.
HELLLLP MR. WIZARD!!!!!
