James duff 5.5 lift question/problem | Ford Explorer - Ford Ranger Forums - Serious Explorations
    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership! If you have an existing Elite membership contact me by PM and I will upgrade your account manually.
VAUGHN4wd
Stanwood Wa
1991 ford explorer
Hey guys I have a 91 ex with james duff 5.5 inch lift w/extended radius arms and I'm having a problem with the inner axle popping out of my diff. Lift has been on for about 3 years or so and never had a problem until my last wheeling trip. I had a Detroit in the front no c clip or c clip eliminator installed, wheeled fine for 2+ years that way never having the inner axle pop out on me. Just before the last trip I changed from the Detroit to an arb and did the 44 knuckle conversion and c clip eliminator spring. Last wheeling trip the spring popped the cap out of the inner passenger axle and my inner axle came out of the pumpkin. The duff brackets are double drilled but I have always ran them in the upper holes. About a year ago I had to cut the bracket that holds the drivers beam because it bent over on a rock. Have I been running the beams in the wrong holes of the brackets? I did a trail fix but I want to do it right. Can someone tell me the distance of the last hole for the drivers side beam to the frame because ill have to cab another bracket? Sorry guys I know its a lengthy read but all help is appreciated!
RangerX
Elite Ranger
Staff member
Moderator
Omao, Kauai
'93 Ranger XLT 4X4
I'm guessing you're talking about the axle drop down brackets? I would guess the double holes are for 5.5"/3.5" lifts, I know other brands have done that.
But I don't see how the amount of lift you're running would matter at all to the axle slipping out. Too much lift could cause a driveshaft to slip out...
Maybe your c clip eliminator spring isn't strong enough, or isn't doing what it's supposed to do in some way.
