Early Bronco 5.5" Coils #5109 $170
3.5" Coils #5107 $160
HD Coil Buckets #5110 $125 For spring steel frames require drilling countersunk holes for mounting. We used 1/2" x 1 1/2" Flat Socket Caps, 1/2" flat washers and Nyloc Nuts. The placement and number of bolts will vary depending on bucket placement and lift height and if the end user is going to stretch the wheelbase.
Lower Retainers #5120 $75 If using EB coil springs, no modification necessary. If using a larger wire diameter coil (like 78-79 springs), it will require either stripping a little of the coating or opening up the retainer loop a touch.
Stage 3 Long Travel Tubular Arms #5351 $749
New Bolt on Dual Shock mounts #5225 $100
Track bar drop bracket #5410 $149
12" Travel Shocks #8114 $36x4=$144 Taller lifts could use our 15" travel #8120 which run $45 each
C-bushings Depends on lift height $29-39
This is from JamesDuff.com
I emailed them. This is what they sent me back.
