ovrlndr
- March 6, 2019
- NS
Ok here goes, my build thread.
It's a '92 and has only 80k miles.
The build will be in 2 stages over the next 3 years;
Stage 1, fix the current problems, add a 2 inch spacer and 3 inch body liff, bumper, winch, 33's....wheel it!
Stage 2, SAS (I have a mid 70's d44/9" with 4.56's), maybe 302
It's 2 stages because a SAS wont pass a safety inspection, so in 2022 it'll be antique plated where there are less restrictions and no safety inspection.
Stage 1
Fixes needed
Drivers exhaust manifold is cracked - probably needs full exhaust system
No brakes (bad hard line)
No emergency brake cables
Roof rust
Rear tailgate misaligned
Fist sized hole around the filler
All body mount bushings are shot (Daystar bushings on my bench)
Upgrades
2 inch coil spacer (installed)
DIY extended shackles (to be made)
3 inch body lift (Daystar lift on my bench)
Bumpers. I like Brian's bumpers.
CB Antenna install
8 inch LED lights
Keeper 8.5 winch (sat on my bench)
Stage 1
Fixes needed
Roof rust
Upgrades
CB Antenna install
8 inch LED lights
