Got Flex?
Jefe's SAS Project Thread
Suspension / Lift
Front:
SAS (Solid Axle Swap):
Rubicon Express Long Arms for TJ's
Custom D44 (Dana 44) front axle:
-High Pinion
-TJ width (~2" wider than stock explorer)
-TJ brackets
-Chevy outers; 11" disk brakes, Warn premium hubs,
5x5.5 bolt pattern
Sway-a-way RaceRunner coil-overs:
-2" reservoir, 14" travel shock
-dual rate Eibach springs; 250, 300
'94 Explorer steering gear box
-hybrid steering shaft
Custom steering links
-1 1/2" .250 Chromoly
-3/4" heims
Rear:
SOA (Spring over Axle)
Deaver Leaf Springs (Custom)
Warrior lift shackle
M.O.R.E. wheel spacers:
-1" spacer
-5x4.5 to 5x5.5 conversion
Rancho RS-9000X shocks
Tires/Wheels
*New* Goodyear MT/R 35x12.5 on 15x8 Steel rims
Balanced w/ Equal Tire Balancer
Engine
4.0L OHV V6
MAC open air intake
75mm Pro-M MAF/MAS
66mm BBK Throttle Body
Cat-back exhaust w/ Flowmaster 40 and custom 2.5" piping
*New* Bama Chips programmmed SCT X-calibrator
Superlift TruSpeed (Speedo calibration)
Drivetrain
700R4 Transmission
-Bowtie Transmissions Level II
-Bowtie Transmissions TV setup
-Advance Adapters Trans and T-case adapters
-B&M Hammer center console shifter
Atlas II 3.8:1 T-case
Tom Woods Custom Driveshafts
4.88 Gears
Elec-trac Locker (Front)
Powertrax No-Slip Locker (Rear)
Lighting
*New* Diamond cut headlights
-Sylvania Silverstar 9007 bulbs
*New* Diamond cut corners
-silver frosted amber bulbs
PIAA 520 Fog Lights
PIAA 80 Pro XT Driving
PIAA 80 Pro XT Pencil
Audio / Video
Carputer / CarPC -- Computer
-VIA EPIA M10000 Motherboard
--1 Ghz C3 CPU
--512 MB RAM
-D-link DWL-520+ Wi-Fi card
-DVD-ROM
-120 GB Hard Drive
-Innovatek IN-720 -7" 16:9 in-dash LCD Monitor
-Wireless Keyboard/Mouse
-OBD-II and GPS connected
*New* Delphi Roady2 XM satellite receiver
Kenwood KGC-6042A -- EQ/X-Over
Profile CL440 -- 40x4 Amp
Profile CL600M -- 300x1 Amp
Boston FX8 -- 5x7 Speakers -front & rear
JL Audio Stealthbox -- Sub Enclosure
JL Audio 10W6 -- 10" Sub
Lightning Audio Cap & Wire
B-Quiet Extreme -- Sound Treatment
Misc.
Front / Rear tow hooks
Lund Speed Grill
Cobra 75 WX ST
K30 magnet-mount CB antenna
Powertank PT-10 -- CO2 tank
TrailHead Tire deflators
Garmin eTrex Vista -- GPS
Dual Optima Red Top Batteries
Custom Rock Sliders
Custom Rear bumper & tire carrier
*New* Custom Front bumper & winch mount
*New* Superwinch X9
Ready-Welder -- 24v welder
*New* 01+ Sport white face gauge cluster
Autometer Transmission Temp Gauge
Autometer Coolant Temp Gauge
*New* Dynojet Wide Band Commander Air/Fuel Monitor
Planned Mods
Roll cage
Built 4.0 OHV V6
-Comp Cams 410 cam
-Ported Heads
-JBA headers
-24lbs injectors
-BBK Supercharger
Manual reverse-pattern valve body for 700R4
Wish List
Custom rear gas tank
4 link rear suspension w/ Coilovers
Suspension / Lift
Front:
-High Pinion
-TJ brackets
5x5.5 bolt pattern
-3/4" heims
Rear:
-1" spacer
Tires/Wheels
Engine
4.0L OHV V6
MAC open air intake
75mm Pro-M MAF/MAS
Drivetrain
700R4 Transmission
4.88 Gears
Lighting
PIAA 520 Fog Lights
Audio / Video
--1 Ghz C3 CPU
--512 MB RAM
-DVD-ROM
-120 GB Hard Drive
Misc.
Lund Speed Grill
Cobra 75 WX ST
Custom Rock Sliders
*New* Superwinch X9
Planned Mods
Roll cage
Built 4.0 OHV V6
-Comp Cams 410 cam
-Ported Heads
-JBA headers
-24lbs injectors
-BBK Supercharger
Wish List
