batesfusion
- August 11, 2014
- Michigan
- 2006 Explorer
This is hard to explain but...
2006 Explorer Eddie Bauer 4.0 AWD
When the truck is cold it doesnt do it but it does when warmed up after driving for a few minutes.
When its around 1500-2200 RPM in any gear and you give it just enough throttle to drive at a steady speed it will start jerking and bucking. IF you give it more it will go away. It does it from 2nd gear all the way up to overdrive. Even more noticeable when im pulling a small trailer. No Check engine light though. It threw one once for an egr code so i replaced it but it didnt fix the problem.
Ive recently replaced...
EGR
TPS
Plugs
wires
coil
MAF
PCV
Harmonic Balancer
and had no change after any of this was replaced
frustrated to say the lease
EGR
TPS
Plugs
wires
coil
MAF
PCV
Harmonic Balancer
