If I was to have a D44 from an '07 JK available (like a brother-in-law going 1-tons), including all the steering components (pump, pitman arm, etc.), and bought the Clayton's long arm kit which includes a tranny crossmember for mounting the radius arms (assuming it will fit between the frame rails)...would I be on a good track for starting a solid axle swap? Any obvious problems I'm missing?
Of course, I have to figure out the frame widths of both the JK and my Sport Trac to see if the long arm kit could work at all. It's a bolt on to the JK and obviously not going to be so with the ST, but maybe with a lot of measuring and a little luck, it could work???? Link to the kit: http://claytonoffroad.com/product_info.php/cPath/15_130/products_id/360?osCsid=771450e8fa86d10e1394266558293e91
It's already geared 4.10, so I'd probably stick with that at least for a little while. I would hope to be able to keep ABS. Plus, it's obviously already locked. I would just need to lock the rear. I'd most likely stay with the 8.8 in the rear. I'll probably run 35s, so the 4.10s won't be too terrible. The top speed in my town is 45mph anyway. The Tahoe is our highway workhorse.
If I'm way off base here, let me know. I'm really green when it comes to this and still trying to figure out where I'm going with this. A solid axle is definitely in the plans, but when and how is still being worked out.
