Joe's new ride
jrgaylor
Washington
1985 BroncoII
Must be off that D44 he is selling
Join the Elite Explorers for $20.
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
jrgaylor
Washington
1985 BroncoII
I got the rear end swapped over a few weekends ago and ordered new coil buckets yesterday from Duff I may have the front end done around the end of September
Abe Lincoln
wilkeson wa
1993 ranger R.I.P B deuce
c
Maybe the weekend after labor day I can run down to bens and drop off the stuff I have for you.
jrgaylor
Washington
1985 BroncoII
jrgaylor
Washington
1985 BroncoII
Thank you Forrest, I now have the 44 hanging under the ex now:)
Albino 94LTD
Recovering from Moab 2016
Newcastle Wa
White 94 Limited
Callsign
KG7PKQ
Where's the pictures?????
:ttiwwp:
jrgaylor
Washington
1985 BroncoII
blurry but I don't want to go outside to get a new one
whitetrashfab
Tenino, WA
91 sport
still need that track bar? I found it the other day if you want it.
jrgaylor
Washington
1985 BroncoII
whitetrashfab
Tenino, WA
91 sport
Not sure, give me a call. I can leave it outside my shop if Im not around.
jrgaylor
Washington
1985 BroncoII
:thumbsup:
jrgaylor
Washington
1985 BroncoII
getting closer
whitetrashfab
Tenino, WA
91 sport
I pushed my axle as far ahead as I could when I had the EB44. I ran a stock front driveline, the other swaps we did I had to cut it down a little. How did your track bar end up looking?
Diff Whack Daddy
And the Roll Over Posse! Under the Hood Moderator
Staff member
Moderator
Mount Vernon, WA
1st Gen XLT 4dr
Callsign
KG7VTT
I agree, looks like that axle could have gone a little farther forward to clear the rear of the wheel well corner. As it looks right now though, good, but break out the sawsall now before you hit the trail.
jrgaylor
Washington
1985 BroncoII
The steering that came with the axle is not correct for it so I need to order the new tie rods and drag link, once that is in I can build the track bar bracket for the frame side and hopfully the EB track bar will work.
I intend on bringing the axle about 1-2" forward by redrilling the lower coil spring cup and moving the radius arm mounts forward.
jrgaylor
Washington
1985 BroncoII
I need to get this finished up, I bought a 72 Bronco that needs to go in its place
whitetrashfab
Tenino, WA
91 sport
Lucky.... its not the one in winlock for 1200 on CL is it?
jrgaylor
Washington
1985 BroncoII
Looked in the valve cover breather hole, All nice and clean. so it looks like the biggest problems is rust
